97 gt and cobra timing chains
Old 02-10-2010, 08:55 AM
6BANGER98
6BANGER98's Avatar
Question 97 gt and cobra timing chains
I am converting a 97 gt into a cobra and also using the gt block. I wanted to know if I can still use the gt chains, tensioners, etc... I have a set of cobra heads that already have the secondary chains on them so am I able to just re-use the ones I already have or do I need to buy a new cobra set with everything?
6BANGER98 is offline
Old 02-10-2010, 10:23 AM
lizzyfan
Underboss
lizzyfan's Avatar
Personally I would buy all new chains while you are doing this swap, not that expensive and not a bad idea to freshen up!
lizzyfan is offline
Old 02-11-2010, 06:46 AM
6BANGER98
6BANGER98's Avatar
so the cobra chain set up will fit the gt block then correct?
Old 02-11-2010, 06:57 AM
uberstang1
Chupacabra
uberstang1's Avatar
I can't answer you,re question for sure, but what part of PA are you in because if you need cobra timing chains I have a stock set from a 97 with approx 80k miles and im in wilkes-barre area.
uberstang1 is offline
Old 02-11-2010, 02:49 PM
6BANGER98
6BANGER98's Avatar
Im in McDonald or Pittsburgh if you have never heard of it. I have the chains and stuff from the block when I originally took them off. I was just curious to see if anyone knew for sure if they would fit with 4v heads vs 2v. I dont want to use them again if they cant take the extra force etc...
carid
07-08-2016 09:55 AM
11-10-2015 11:39 AM
StalkerGT
09-25-2015 02:41 PM
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
09-08-2015 06:25 PM
Quick Reply: 97 gt and cobra timing chains
