How sticky?
Sorry, I should have been a little more specific. They will be used for the drag strip and for 'closed road' activities I also will be pairing them with a 15x8 rim from either Jegs or Summit (I know they aren't the best rims, but they are a really good price) Obviously my rear-end can handle a pretty sticky tire but I'm not sure what will be overkill for my power levels as stated above by 72mach
I don't know, from what I've run and most other people have run, I'd say 1.85 on stock suspension is pretty close to spectacular. That being said, I don't know what they're like on a 15" wheel, but my 315/35-17 Nitto DR's can break pretty easy on the track if you don't have just the right touch. That's why I've upgraded my suspension and have a pair of M/T's in the garage waiting for install.
I just picked up an MSD Launch Master recently and installed it today. I can't wait to try it out. And it sounds pretty wild, if you're into that kind of thing. Also, if you pick one up, I'd recommend setting up a toggle instead of tapping into the clutch switch.
