Bad Pulley, I think?
I think one of my pulley bearings has gone bad, but not sure which one. It's making a squeaking noise. I doubt it's the belt because the belts make that annoying screach when they slip. The sueak is consistant with the motors rpm's.
Any ideas on how I can find out which one it is?
Thanks
Thanks
I'm positive it's not the belt. If it were the belt, it would squeal under load. It's a consistant chirp.
Old trick to I.D. bad bearings. Use an old broomstick a foot or so long, hold one end to your ear and place the other on alternator, or whichever accessory U think is going bad, the wood will transmit the sound of bad bearings -sort of like a redneck stethoscope..
As comical and dangerous as this sounds and after a finished laughing, it really seems like it would work. I don't think I'll be trying that one though.
In my quest to find which pulley is sqeaking, I found that my belt did need to be replaced. Went to the local auto parts store and grabbed one for $18. Popped the old one off and decided to check all the pulley's with the belt off.
My idler pulley as well as the p/s dir pulley have a slight wobble to them. When investigating the squeak it came from the general area of the idler. I put the new belt on and there is no longer a squeak, but I still believe I need to change the idler due to the fact that I think the wobble is causing premature belt wear. I don't think I need to change the p/s dir pulley because it has the grooves in it and the wobble is barely noticeable.
What do you guys think?
While your at it i would change both. I just replaced both my idler pulleys this weekend along with the belt, no more noise. The pulleys should not wobble. both idlers are the same. They were 18$ and change a piece.
by the way that trick with the stick, broom handle or whatever does work, the bad bearing will make a grinding metal sound, just be careful!!!
