Replacing Mufflers
You'd basically need 4 of those adapters going from 2 1/4" to 2 1/2", I believe even autozone and some of your parts stores will even carry them, Just make sure when your measuing the muffler and your stock pipes to remember if its ID (Inner Diameter) or OD (outer diameter) that you measured. And like K_Z said a muffler shop should be able to set you up right too, I always have to use the parts store though since the nearest muffler shop is probly a hour away and I do my own work.
09-10-2015 08:39 PM
