Easiest way to install front springs?
^ Ya your right you have to take the caliper off and support it with some wire or on something out of the way. I also took the precaution of unbolting the abs sesnor and moved it out of the way too. Im not sure if you have to on the tie rod ends, I disconnected mine because I had steeda bump steer kit to put on.
09-01-2015 08:16 PM
90, body, change, changing, compressor, cyl, fox, foxbody, front, install, installing, mustang, replace, springs, suspension
