Steering wheel is feeling a little rubbery...
What causes "rubbery" feeling steering? This is a very recent issue... the roads are fine, it's most apparent at slower speeds, I turn the wheel, and there is a very distinct rubber feel...
It may be a permanent compression the steering rack mounting bushings, usually they creak too but not always--it was one of the first things I fixed on my '03.
The steering shaft also has a bit of play in it and that may be causing it. I just swapped the stock piece for the MM solid steering shaft and am loving the difference. The steering wheel no longer has any play in it and is extremely responsive.
09-08-2015 11:50 AM
