Delta Force tuning software ?'s
#21
If it's a direct bolt-in that has the same transfer function then it's a stone cold waste of money as it would be the functional equivalent of the OEM unit.
#23
However as I said earlier, this is quite a bit less than a plain ol' stock 80mm MAF from a '99 to '04 GT can measure. I don't understand why you want to use it on your car, why aren't you looking at the larger diameter housings VMP offers?
Also, in a blow-through installation you need yet a larger MAF as the elevated intake air temperatures make the air less dense, despite its being compressed...
#24
Idk, it said it can support the hp I was planning on making and thought that if I had a 3" pipe from the intercooler to the 95mm Bazooka or the BA series it would mess with the maf since it will be stepping up and then back down again to go the the t/b. Do you see no problem with that? Since I honestly don't know what maf would you suggest for a setup like this. Forged .020 over 4.6 with Trickflow heads, edelbrock intake, turbo cams, 60lb injectors, twin 255lph pumps and an on3turbo kit with the Masterpowers upgrade. Should I just go with the bazooka or the ba3000 and call it a day?
#25
I don't know, as I said actual mass air measurement gets strange in blow-through situations because of the extreme air temps. If your inter-cooler is 75mm then I suppose there really isn't any point of having a larger MAF housing, however I am certain that 2650lb/h of air (as is indicated at 5.0V output on their worksheet) will not support much more than 400 fwHP at 11.5:1 AFR. The stock 80mm unit can do better than this.
2650lb/h of air / 11.5:1 AFR = 231 lb/h of fuel. At a BSFC (Brake Specific Fuel Consumption) of 0.6lb/HP (rule of thumb for f/i) that's 384 fwHP.
I have never used a blow-through setup, don't like 'em (barring leaks there's nothing that happens to the air in a blower or intercooler that alters it's mass), so maybe there's some magic there, but the numbers they provide don't seem right to me...
#26
Hey even a stopped watch is right twice a day
This would explain why my PCM does not experience this issue but most of the cars / trucks I have tuned have been affected. I never seem to touch anything that's not 2002+ and normally a lightning or a Cobra.
#27
#29
The RoT sizing formulas are starting points for selecting the right components in the first place, not 100% infallible calculations.
Nonetheless, when someone say they are supporting 640 HP with 2650lb/h of air my meter goes:
#30
