EGR emergency! BBK LT install, HELP!
probably the last thing a person in my situation wants to hear.. you can keep that kind of information to yourself next time[/QUOTE]
Sorry man but I honeslty never had a problem, just curious but did you buy the ceramic coated ones? because mine lined up great but it did turn fairly tight because of the coating on the threads. Glad to hear you got it though, if I remember right mine was completely tight but there was still a few threads showing because their bung or whatever you'd like to call it is plenty long to get it tightened up. Its a tough install and takes alot of patience and knuckle banging.
to Nestang: no, mine are chrome. like i said, i didnt have any thread showing, but theres a spot right under the threads thats just blank and that spot is exposed. but since it seems like the egr pipe, or "nipple" as rik_0_1 called it, is very well sealed, and will be even better sealed after i go over it with hi-temp sealant, im more than satisfied. got everything back together, now just need to put the h-pipe on and wait for those damn o2 extensions...
to rik_0_1: not sure what you mean, what about the plenum? what does that hafta do with the install? are you referring to the plugs attached to the egr assembly, which it bolted onto the plenum, but is not actually a part of the plenum itself? i'm confused
the thing the egr is attached to is called the intake plenum. he deleted his egr so he needs a plate to cover the hole in the plenum where the egr used to be. and good luck trying to get the oil dipstick back in. the biggest PITA ever and i installed shorties i can only imagine the lack of room with long tubes. even if you do get it through the manifolds and somewhat lined up with oil pan good luck getting any leverage to seat it.
anyway, odd thing about the dipstick.. three days ago, i tried jamming the thing down in there, bending it a little, etc. the next day, i bent it more, broke it in half, and ordered a new one from my friend at ford. in the meantime, i installed the k-member, motor mounts, etc.. then yesterday when the dipstick came in, i realized i needed to take out the damn motor mount to put it in. HOWEVER, once i did, the dipstick pretty much slid right into place. crazy!
your right, it does connect to the plenum, but i was confused about the way he worded it.. its not really a plug that goes into the plenum, more like a whole assembly, the only "plugs" are attached to the EGR, if that makes any sense.. ?
I went with one of these Lokars for a dipstick, I like it alot more than the factory. She can get pretty warm after a long trip but it works and looks great.
http://www.summitracing.com/parts/LOK-ED-5014/
Luke9222
10-22-2015 11:55 PM
TfcCDR
09-14-2015 12:08 PM
