Taking out my A/C
well once your car gets modded so much its kind of hard to sell it. My car has 207,000 miles on the body. New engine has about 30,000 miles on it. Has a creaky tubular suspension, plus normal wear an tear. As it sits right now I wouldnt be able to get anywhere near what i put into it back. I probably wouldnt be able to sell it for more than $10k unless something magical happened. But thats more of a reason to keep it. Theres no way I could buy 10 seconds for less than $50k on a dealers lot
hey i think people here are bieng a little harsh. others have been deleting the ac for years. I deleted mine because I never used it beforehand and it frees up a ton of space under the hood. It drops nearly 50lbs and the delete pulley you buy will free up a few hp. Its less weight compared to the compressor pulley. As for resale value, the whole ac can be reinstalled in less than 2 hours if you know what your doing. Plus if the car is modded at all youve pretty much already lost your high resale value
OP, if you don't want/need the a/c, pitch it. Just the simple job of relocating the battery from the front to above the right rear tire puts 60lbs on that tire to help with traction. Every little bit of weight you get out of the engine bay helps.
Funny you say that, I am getting the Steeda Battery relocation kit, does it have to be over the RR tire? also I looked on american muscle and I am going to just get the FRPP kit, 50 bucks, quick switch, so alls well ends well, and yea when my dad took his out it weighed about 45 lbs, it was like 48 lbs, but thats all the AC components.
I can't remember, for the life of me, where I saw it.
my mistake.....not right over it. Behind it. The battery may only weigh 25-30lbs, but while lauching it's its inertial weight becomes something to the affect of 60lbs. There is actually a mathmatical eqation for the effects of this specifically and taking other weight out of the front.
yea that all makes sense, but if you guys could i only know of the AC and Battery is there anything else im not thinking of, every little bit...im getting a rear seat delete kit just because I dont use it and no one can fit behind me.
