Hood Pin question
Hey, I couldn't find the exact write-up that I used when I did mine, but this one might have some info and pics to help you out. Good luck!
http://www.lonestarstangs.com/forum/...ang-24875.html
Is there a reason you couldn't sandwich a big washer and nut on either side of the sheetmetal to hold the hood pin in place, instead of welding the nut to it? I'm wondering, just in case I wanted to go back to my original hood and still use the rubber bump stops, without cutting or grinding the nut back off. I was going to get stainless Ford Racing hood pins. Are the hoodpins to short for this?
