help - clutch pedal vibration
Old 03-15-2010, 04:09 PM
smashten
smashten's Avatar
Default help - clutch pedal vibration
Just had a new clutch, pressure plate and throwout bearing installed. Sitting in neutral I get vibration but I also get it when I am in gear. slight pressure on the pedal gets rid of the vibration without disengaging clutch.
Is the vibration being caused by the bearing riding up on the pressure plate springs? If so are there keepers that hold the throwout bearing off the pressure plate springs until engaging?
I realize after reading a bunch of posts that I should have used an OEM bearing, but I'm trying to figure out what the chances are it was installed incorrectly or if the CF bearing is defective.
Any help is appreciated
smashten is offline
Old 03-15-2010, 04:17 PM
a_penquin
a_penquin's Avatar
It definably points to the bearing. Its either a defect, or they didnt clip it in right.
a_penquin is offline
4cylinderplus2
10-09-2020 07:45 PM
baddog671
07-26-2016 01:20 PM
Thunderball
15
11-22-2015 11:49 PM
junior04
09-28-2015 10:53 AM
ThatJuanStang
09-25-2015 08:01 AM
Quick Reply: help - clutch pedal vibration
