How hard is it to remove the front bumper cover
Old 03-19-2010, 05:20 PM
green2000gt
green2000gt's Avatar
Default How hard is it to remove the front bumper cover
I need to remove the front bumper cover on my gt to install the mach 1 grill delete the right way. I first tried doing it like this guy says http://members.***.net/red9r/Install...01%20Grill.htm
but I do not have hands the size of a five year old and even with pulling back the bumper I could not tighten the screws and see what I was doing. So I just put two layers on 3m doubled sided trimm tape on the curved part that goes on the bumper like everyone says to and it seemed to work really good but after 2 day of sitting in the sun the tape is starting to unstick and lift, so I just want to remove the bumper and get it done the right way to make it look good. I know this is allot of work for a little part but i am picky about my car and this bugs the crap out of me. I also see that when you buy a new bumper it come with rivets, is the cover riveted on? anyone have any pointers that has removed it before?
green2000gt is offline
Old 03-19-2010, 05:43 PM
vanquish
vanquish's Avatar
It is just a bunch of those plastic push screws I don't know what they're called. There are also two bolts holding it on where it meets the fender. I isn't too hard to remove and it doesnt take too long.
You will probably need to buy new plastic screws at the hardware store unless you don't damage the ones you have now.
vanquish is offline
Old 03-19-2010, 08:37 PM
green2000gt
I kinda thought about using some body adhesive and glue the part to the bumper but if I have had my car painted ( I plan on it in a couple of years) I would be screwed
Old 03-19-2010, 08:44 PM
dr.apex
dr.apex's Avatar
I had my front bumper of two days ago. It takes 10 minutes to pop it off. Those rivets are actually plastic, like previously stated. If you carefully remove them they can be reused as I did. There are a few screws in the fender well that you need to take out. It's very easy.
dr.apex is offline
Old 03-19-2010, 10:52 PM
StockD15b
StockD15b's Avatar
a couple plastic screws up top. cant remeber exactally how many. 2 plastic push pins on the underside of the cover, closer to the center of the veichle. 1 screw in each fenerwell that holds the cover to splash sheild. 4 7/16's bolts,2 on each side. after you push the splash sheild outa the way you should be able to reach em. Deep well socket indeed needed.
StockD15b is offline
Old 03-19-2010, 11:07 PM
m260gt
m260gt's Avatar
i got the grill delete on without taking off the bumper. its on the right way. it took a long time and i have cuts from forcing my hand in there but it can be done. and i dont have small hands. with the right tools it can be done.
do it like this
http://www.americanmuscle.com/mach-g...o-install.html
i think mine looks good
m260gt is offline
Old 03-20-2010, 12:38 PM
chrisgtr
chrisgtr's Avatar
^^^ you need to undo part of the splash shield. once you have that where is moveable, you can reach the two screws where the bumper and fender meet. buy the new plastic rivets... you will mess the old ones up.
chrisgtr is offline
Granatelli Sales
01-20-2020 12:34 AM
svastano
25
07-16-2016 01:20 PM
JonnyBlazeGT
11-03-2015 01:10 AM
whatsup62
09-03-2015 01:38 PM
MustangHead91
08-23-2015 09:37 PM
Quick Reply: How hard is it to remove the front bumper cover
