HELP stang wont stay running
Old 03-19-2010, 08:20 PM
brys00gt
brys00gt's Avatar
Default HELP stang wont stay running
I just finsihed installing my p-51, new rails and 24# injectors. I had Eric Brooks make me a new tune for this and uploaded it to my mustang. The car will not idle, and barely runs on throttle. It is running very rich and is not burning all of the fuel. Any suggestions?
brys00gt is offline
Old 03-20-2010, 07:04 AM
brys00gt
brys00gt's Avatar
These are the codes that I have right now:
P0206 Injector circuit open cyl 6
P0207 Injector circuit open cyl 7
P0102 Mass or volume air low
P1000 OBD systems
P1504 IAC circuit
P0135 02 Heater circuit
P0155 02 Heater circuit
I believe I fixed the IAC code as the line was pinched. Any ideas on the rest?
brys00gt is offline
Old 03-20-2010, 11:52 AM
0949er
0949er's Avatar
is the tune ok? Did you "sand" the contacts so that the chip can make a good connection? The stock computer has some kind of "coating" over the contacts that will prevent a chip from loading
0949er is offline
Old 03-20-2010, 12:41 PM
brys00gt
brys00gt's Avatar
I loaded it with my diablosport predator and it said loaded successfully
brys00gt is offline
Old 03-20-2010, 01:34 PM
Hangwire
Hangwire's Avatar
Obviously the engine isn't getting the air it needs. Its either related to your p-51 install or something else unrelated that got disconnected or messed with unintentionally. After checking these things I would double check the tune to make sure its right for your upgrades.
Hangwire is offline
Old 03-20-2010, 10:46 PM
98cobraguy
98cobraguy's Avatar
Default injectors
maybe one of your injectors are clogged
98cobraguy is offline
Old 03-26-2010, 03:13 PM
brys00gt
brys00gt's Avatar
Looks like my PCM is fried, new one coming tuesday.
brys00gt is offline
MusicCity615
09-12-2015 07:05 AM
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
v8sn95
09-07-2015 10:17 AM
Luke9222
09-04-2015 06:46 AM
Quick Reply: HELP stang wont stay running
