Wheel and tire fitment help
Im trying to order some new wheels and tires for my mustang which is an 02 gt i want to run 18x9 in the front with 275/35/18 tires and 295/35/18 in the rear but i called AM cause i want to run the fr500 wheels and the person i talked to said that i would have fitment issues cause i am also running the eibach springs and that i would have to roll my fenders and that that size up front would cause the sway bar to hit any help would be great!!!
You may rub a bit, but rolling the fenders a tad is not a big deal. The 275's tend to hit the front sway bar, but only a little and on full-lock of steering wheel so no worries there. The rear tires will be OK, but a 30 series will give you a bit more clearance as well as limit the likelyhood of ABS sensor issues due to a bit excessive differing diameter tires between front and rear.
Jazzer
EDIT: You could avoid rubbing if you go 265/35's in stead up front. I think this is a better fit for a 9" wheel anyway. The 275's tend to be a bit sloppy on turn-in response with a 9" wheel.
Jazzer
thank you so much for the info the guys at AM worried the hell out of me so i think i will go ahead and order the wheels and tire and one more thing what do you mean about turn in with the 275's you mean it wont be as responssive!
yeah I used some calculator online and change the tire rotation numbers according to its calculations, i havent been able to test its acuracy with gps, but I havent ever been pulled over or noticed any difference once I adjusted it with the diablo
09-16-2015 07:53 PM
09-08-2015 11:50 AM
