yet another clutch issue need help please!!!!
Old 03-21-2010, 11:37 PM
caynor
caynor's Avatar
Default yet another clutch issue need help please!!!!
ok, i looked through all the clutch adjustment links and couldnt find my problem...might have over looked it so sorry in advance...
now i have had alot of mustangs between 83- 92 and i know about pulling the clutch pedal up to adjust... my problem is... i have just bought a 97 gt with 69000 miles and the clutch releases like a 1/2 inch from the floor if that...i mean its right on the floor!! i prefer it at the top.. i asked a local mechanic if i could adjust it and he said it was hydraulic so no i couldnt....its suppose to be a 2yr old clutch...so my question is can i adjust this clutch to get it off the floor or is it toast...i'm new here so howdy all and your help would be great.... thanks
caynor is offline
Old 03-22-2010, 06:03 AM
uberstang1
Chupacabra
uberstang1's Avatar
You're mechanic is a schlep, you're clutch is not hyrdraulic its cable. Did you check to see if it has an aftermarket quadrant?
uberstang1 is offline
Old 03-22-2010, 08:45 AM
Fizzics Boy
Fizzics Boy's Avatar
Sounds to me like your cable is stretched out. I would go check to see if the quadrant is stock or not. If it is, go out and buy an aftermarket one, along with a firewall adjuster and a new FORD cable. Stay away from the aftermarket ones, as they tend to snap. My friend broke 8 of them within a year.
Fizzics Boy is offline
Old 03-22-2010, 09:18 AM
caynor
caynor's Avatar
what is a good aftermarket quadrant and firewall adjuster to buy? i thought the mechanic was wrong also..but, i've never owned this year of a stang... how much all this going to run? thanks
caynor is offline
Old 03-22-2010, 09:48 AM
Fizzics Boy
Steeda and Maximum motorsports are both good. They will run you about 80 bucks for the two parts. Maximum motorsports also sells a ford cable for 67 dollars if I remember correctly. figure it should be around 150 for all the parts.
Old 03-22-2010, 04:54 PM
caynor
caynor's Avatar
how can you tell if the clutch IS stretched? i dont want to buy all these parts if thats not the problem...
caynor is offline
Old 03-22-2010, 08:12 PM
cliffyk
TECH SAVANT
cliffyk's Avatar
How much free play is in the pedal? Should be 1-1/4" to 1-1/2" max...
cliffyk is offline
AmericanMuscle4.6GT
11-10-2015 02:06 PM
ccdguy
09-19-2015 05:20 PM
PNYXPRESS
09-14-2015 09:50 PM
MasterLanMan
09-13-2015 08:21 PM
Emblazoned
09-03-2015 10:45 PM
Quick Reply: yet another clutch issue need help please!!!!
