SPARK PLUGS IS THERE A DIFFERENCE BETWEEN CHEAP AND EXPENSIVE???
Old 03-24-2010, 10:53 AM
noroofonthecoupe
Gimme a cupcake & a pat on the head
noroofonthecoupe's Avatar
Yeah I didnt think there would be a huge difference between the expensive and the cheapies unless you're doing some high performance ish....What about the dual spark things Im not sure the name but instead of one tip they have 2 going on the bottom??
noroofonthecoupe is offline
Old 03-24-2010, 11:19 AM
Moonshine
Moonshine's Avatar
It's all just a sales gimmick.
Moonshine is offline
Old 03-26-2010, 12:57 PM
clubplug
clubplug's Avatar
Hi Folks
Sorry but I just had to reply.
The major difference between inexpensive (copper plugs) and expensive (Iridium) plugs is the following:
If we take brand new copper plugs and place them in the vehicle, then do a test (Dyno) they will give you very good results compared to brand new Iridium plugs.
However, over time (approx. 8-15 months) the copper plugs will wear out faster and there is where the expensive plugs will out perform the copper plugs.
So, if you do not mind changing the plugs a lot sooner, then stick with inexpensive copper plugs. If on the other hand you want to keep the plugs in the car for 40 000 to 60 000 miles or if replacing the plugs in your vehicle is a pain in the butt, then spend the extra and get iridium plugs.
clubplug is offline
Granatelli Sales
03-25-2016 08:01 PM
2007StangV6
01-28-2016 06:09 PM
Golfsito
10-06-2015 11:02 AM
uedlose
09-10-2015 03:30 PM
Emblazoned
09-03-2015 10:45 PM
Quick Reply: SPARK PLUGS IS THERE A DIFFERENCE BETWEEN CHEAP AND EXPENSIVE???
