Weld wheel questions
Old 03-29-2010, 09:19 PM
smythge
smythge's Avatar
Default Weld wheel questions
I need to go with a 28" tall back tire, wondering if I would have any clearance problems in the back with 275/60 15s with 15x8s 5.5" back spacing? I was looking at the 15x4" fronts seems like everyone is running 155/80s which is less than a 25" tire, would I have issues with my ABS running 25" in the front and 28" in the back?
smythge is offline
Old 03-29-2010, 09:52 PM
tbirdscwd
tbirdscwd's Avatar
You should be fine front and back with the sizes you mentioned, but you will need 7/16 wheel spacers up front to clear the brake calipers.
tbirdscwd is offline
Old 03-29-2010, 10:10 PM
lizzyfan
Underboss
lizzyfan's Avatar
I ran 275/60/15 with C springs (lower then stock) with zero issues
lizzyfan is offline
Old 03-30-2010, 06:54 AM
smythge
smythge's Avatar
What size did you run on front?
smythge is offline
Old 03-30-2010, 01:08 PM
lizzyfan
Underboss
lizzyfan's Avatar
15x6 205/60/15 with 4cyl Fox springs
lizzyfan is offline
Old 03-30-2010, 04:20 PM
grogan
grogan's Avatar
i run 275/60/15s on my car and ive had rubbing problems since the day i put them in. i switched the lower control arms to maximum motorsports adj. to raise it 2 inches, still didnt fix, then i had to change the rear springs to a set of qa1 300 lb 14 inch springs and that is what i currently run. as far as i know i have no rubbing but the car looks like a monster truck in the back.
up front i run the 155/80/15s on a 3.5 weld and i use the 7/16th spacer.
as for the abs all i did was put a piece of electrical tape over the abs light cuz it doesnt go out. as far as brakes go, they seem to work fine. they do 110 to 0 without problems.
grogan is offline
Old 03-30-2010, 04:41 PM
smythge
smythge's Avatar
I've got drag springs in the front and back so mine looks like a 4x4 also, I am debating skinnies in the front or a 6" wheel with something a little larger.
smythge is offline
Old 03-30-2010, 04:48 PM
99BlackPonyGT
aka 'Negative Nancy'
99BlackPonyGT's Avatar
heres the spacers you will need for the front...dont let people talk you into those $200 hubcentric road racing bull**** spacers...these are fine, run them on my car with no issue at all
http://www.jegs.com/i/Mr.+Gasket/720/2372/10002/-1
99BlackPonyGT is offline
Old 03-30-2010, 06:52 PM
lizzyfan
Underboss
lizzyfan's Avatar
That's what I run
lizzyfan is offline
Old 03-30-2010, 07:19 PM
grogan
grogan's Avatar
wish i knew about the 15 dollar ones before i paid 50 bucks for mine....
grogan is offline
Quick Reply: Weld wheel questions
