Left my car sitting for 4 months
#22
ok i got the tank down. the fill hose is stil in it but i can access the top of the tank easily. stupid question but the fuel pump is accessed through the top of the tank by unscrewing the 6 screws in the round lid on top right??
#27
here is the pic i am using for reference. do i have to take that whole thing out or can i take the pump out from there. also i dont even see the pump in there to take out??? i am getting close i just wanna get this done already.
http://images.google.com/imgres?imgu...26tbs%3Disch:1
#29
I just came back from 7 months and my car turns over and all had to replace the battery too, but it will start and then stall and it happened leaving the restuarant tonight. Does this sound like the same problem? I had to hold the gas down for and rev up and then it still died a few times, the idle was also a little jumpy. After that it worked fine no problems... do you think a little sea foam or injector cleaner would help or should i take the fuel pump/filter route?
#30
SUCCESS!! i finally got the unit out, replaced the pump, put everything back together, replaced the filter and connected the battery. turned the key, heard the pump and it fired right up. now im gonna let it set for a couple hours and look under the car for any leaks. all this and not extra pieces left over thanks for all your help people, im sure i will be calling again.
