Brief sqealing sounds when starting to accelerate
#21
Is anyone who has experienced the "french horn" sound able to confirm whether this is the same or not? It would be very helpful to rule that out if that's the case. I will update after I have it looked at.
#22
I had the car looked at again today and the mechanic was able to hear the noise.
They couldn't figure out what it was, and visually could find no problems. He said
that it doesn't seem to be an issue, so I might have to let it take it's course. He also
mentioned that it could be the pilot or throwout bearing, but that it didn't fit the normal
description of that sound. Driveability hasn't changed over the last few thousand miles.
I also had a local friend look at it and he mentioned that it could be something with the e-brake binding, as he felt that it was coming from the back of the car. The mechanic said that this was unlikely, though. I still can't figure out exactly where on the car the noise is coming from. Originally I thought it was the front.
So basically, I think that it is either the "french horn" sound, or the beginnings of a drivetrain issue. If anyone can compare the sound in the vid to the "french horn" and let me know if it's similar, I'd appreciate it. Thanks.
#23
Thats what I thought as well.. There is a bushing that goes from the drive shaft into the rear differential.. It could be worn out enough to let the shaft joint settle againt the housing while left still.. Just a shot in the dark tho. It should be easy to tell if thats the case by looking at where they connect.
#24
#25
I would put the axle on jackstands, chock the front wheels, and lay under the car then let a buddy put it in gear the tap the gas. Its free and im sure you will know where the sound comes from then.
#26
Yeah, I've been meaning to do that. It is so random when it happens but it's worth a shot.
#28
#29
hard to tell from that clip, but mod motor pcv valves wil make a high pitched and very fast rattle. it'll almost sound like a squeal. pull the pcv valve out with it running and see if its noisy and vibrating. it will also make that noise for a few seconds after u shut it off.
