MHS stage 2 cams
#83
Rod I got a question for you. So far it seems people are comparing peak to peak levels, do you know what gain you have at say 5000, 5500, and 6000? I was recently talking with someone who wants to make 450RWHP NA and told him to use 320RWTQ as a constant and start plugging it into the HP and RPM calculator to see what RPM it will need to run at. Most 4.6 NA motors in a serious build will do 320RWTQ give or take, street ones can do it at lower RPM and race ones will do it at crazy RPM.
#84
edit: You'd probably need to shift close to 8,000 when running that setup!
#85
I can tell you this though: With the rev limiter bumped to 6600, it pulls very well to 6300-6400. At some point i'd like to get it back on the dyno, and see what the curve looks like at the higher rpm's.
jwog666
12-27-2021 08:09 PM
junior04
09-28-2015 10:53 AM
09-25-2015 09:06 AM
