Last edit by: IB Advertising
Browse all: Powertrain Guides
- Ford Mustang Gt 1996 to 2004: How to Replace Motor Mounts
Step by step instructions for do-it-yourself repairs
Stripped motor mount nut
Well there are two types that i am familiar with.
The first is the basic one piece, works like the stripped nut remover. it is longer though, and obviously comes in smaller diameters to match stud sizes.
I have not personally used this type.
The second, is the the cam lock style. It uses simple mechanical ability to bind against a stud allowing use of a ratchet (and extension if needed) to remove studs. I used this on my ranger when i was doing the headers, as i managed to strip the nut as you have done. I'm like, wtf do i do now!!! A guy at the plumbing shop I worked at used to be a mechanic, and he's like, hey, dummy, try this. All I did was spray some PB blaster on the stud and let it set a while, then out it came. Pretty simple really. If you have like 9/32" of length on the stud to grab, that's enough for one of these puppies to work. Here is a link for a bunch of different ones.
Good Luck!
Good Luck!
Of course, you could always just try something fun! Take a socket(the correct size that normally fits the nut that's stripped), fill it up completely with JB weld...Stick it on there for a day or two(hold it is place with wire or tape or something(don't drive the car obviously lol). After it has hardened, just stick the ratchet and extension on there and push towards the motor while giving it torque to crank it loose! I don't guarantee it will work...but it might! If nothing else you could then say it DIDN'T work! haha
exactly.. If nothing else.. use a brazing tip on the torch and angle it away from the block, but 2 nuts on the stud locked together will do the trick. tighten them up with two wrenches and use a socket to break the stud away.
However, I do not believe the single mounting post at the bottom side of the OEM motor mount is a removable stud.
I haven't held a mount in my hand for some time, however IIRC it's a upset mounted/welded fixed stud.
