Need help with timing a '98 GT
Old 04-30-2010, 09:50 AM
ricksmastermix
ricksmastermix's Avatar
Default Need help with timing a '98 GT
We're new to the Mustang forum.
My son, recently, had his '98 GT heads rebuilt and is in the process of reinstalling.
What is the process for setting the timing with the 4.6 sohc engine?
Thanks.
ricksmastermix is offline
Old 04-30-2010, 10:37 AM
Stevecooper
Stevecooper's Avatar
Thanks.
http://www.modulardepot.com/articlesp.php?aid=32
Stevecooper is offline
Old 04-30-2010, 11:25 AM
ricksmastermix
Thanks. Just what we needed.
Old 06-14-2013, 06:25 PM
Spencerestes
Spencerestes's Avatar
How do you time a 1998 gt mustang the link doesn't take me to where I need to be dedicated
Spencerestes is offline
Old 06-14-2013, 09:57 PM
school boy
school boy's Avatar
http://www.modularheadshop.com/camdegree.aspx
http://www.modularheadshop.com/caminstallation.aspx
http://www.modularheadshop.com/pisto...clearance.aspx
heres a few articles
school boy is offline
Old 06-15-2013, 08:14 AM
Spencerestes
Could I just match the markings on my cam and timing chain and the motor be timed ?
Old 06-15-2013, 09:31 AM
Stevo86
Stevo86's Avatar
You need to set the #1 piston at TDC and the cam gear should be a bit outside of 12 o'clock. Yes if you line up the marks on the cam gear, timing chain, and crank gear you're good.
Be sure not to rotate the cam or crank with the chains off and cam caps tight. You can bend valves that way. You need to loosen the cam, set it where it needs to be, then re-torque it.
Stevo86 is offline
mungodrums
10-07-2015 04:01 AM
clowe1965
Carolina Regional Chapter
34
09-28-2015 09:18 PM
StalkerGT
09-25-2015 02:41 PM
09-08-2015 11:50 AM
Quick Reply: Need help with timing a '98 GT
