Ac not working
Old 05-09-2010, 08:52 PM
96mustanglx
96mustanglx's Avatar
Default Ac not working
My ac isn't working. I checked the fuse under the dash and it's good and has power. The clutch won't engage on the compressor either. I don't have power to the plug on the compressor. I was told that it could be the ccrm (constant control relay module). Has anyone ever had to replace on of these? If so was it very difficult? Got any pointers?
96mustanglx is offline
Old 05-09-2010, 09:23 PM
wingless
wingless's Avatar
There is a two-prong electrical connection on one of the AC pipes.
Unplug the wires and use an ohm meter to measure continuity.
It should be a short, ~10 ohms.
If it is open, then there is a leak and the freon has escaped.
If there is a leak, then it must be located, the bad part(s) replaced and the system recharged.
wingless is offline
Old 05-09-2010, 09:33 PM
96mustanglx
It's holding pressure so there aren't any leaks
Old 05-09-2010, 09:50 PM
wingless
wingless's Avatar
The compressor won't be happy unless that switch is too.
wingless is offline
Old 05-09-2010, 10:27 PM
96mustanglx
Which switch are you talking about exactly? High pressure or low pressure?
Old 05-11-2010, 04:28 AM
wingless
wingless's Avatar
Both need to be happy.
But, if the compressor isn't running, then the evaporator won't be iced up and the high pressure switch won't have opened.
So, checking the low pressure switch to ensure continuity is a good first step to seeing why the compressor won't run.
wingless is offline
1TUFF302
11-05-2015 04:02 PM
Pyrate Dave
09-10-2015 07:30 PM
96stang3.8
09-10-2015 06:42 AM
JoshyGT
09-07-2015 02:04 PM
cbird1177711
09-03-2015 08:43 PM
Quick Reply: Ac not working
