hard to shift into reverse
Originally Posted by normanbaites
clear the clutch, put it in first, or fifth, or just about any other gear before reverse, i had the same problem and after a while of puttin it in first before reverse, its so normal that i forgot i even had the problem...also if you feel it about to grind, stop!,,, and try clearing the gear...like i said, after a while of that, youll forget you everhad the problem
I do that same thing. I don't even notice it anymore. Sometimes people in my car are like WTF was that? You ALWAYS sound like a tool trying to explain...</P>
OK here's the deal guys. If you've ever seen the inside of a T45 or 3650 tranny you can see what's going on. First of all the stock clutch sucks, and because of that, the reverse gear set doesn't synchronize right, which mauls the teeth on your reverse collar. The longer this goes on, the worse the teeth get, which makes it harder for the reverse gear to engage. I saw mine when I had my tranny rebuilt and the teeth looked pretty mauled. Replacing the clutch with a quality aftermarket clutch will help, but the damage to the reverse collar is already done, so it won't completely go away until that is replaced, which means a transmission rebuild. <IMG src=smileys/smiley11.gif border="0"> </P>
Ever since I had mine rebuilt, shifting into reverse is a piece of cake.</P><edited><editID>USAMuscle</editID><editDate>37999.8113541667</editDate></edited>
on the inside of the tranny everything is movin around... hold the clutch down for about 10 seconds and see if it still grinds.. its normal... i hate to say it though cuz it sounds like sh**!
<P class=Msonormal style="MARGIN: 0in 0in 0pt"><FONT face="Times New Roman" size=3>Alright, I just wanted to throw in my 2 cents on the reverse tips.<SPAN style="mso-spacerun: yes"> </SPAN>I’m no mechanic but I’ve done a lot of driving in my time – started riding motorcycles at age 5, raced them at 8, drove a stick shift van when I was about 7 or 8, then got the majority of my car shifting experience with my first vehicle, an 84 colt turbo, when I was 15 and on.<SPAN style="mso-spacerun: yes"> </SPAN>Now I’m 35 and like most of us here, take great pride in driving a stick well.<SPAN style="mso-spacerun: yes"> </SPAN>I’ve also witnessed women and men who have driven stick for many years and completely suck at it.<SPAN style="mso-spacerun: yes"> </SPAN>So here’s a summary of Jim’s shifting tips (god, I hope I contribute more to society than this before I die).<SPAN style="mso-spacerun: yes"> </SPAN>Many of these have already been mentioned – I don’t mean to take anything away from previous entries.</FONT></P>
<P class=Msonormal style="MARGIN: 0in 0in 0pt 0.5in; TEXT-INDENT: -0.25in; mso-list: l0 level1 lfo1; tab-stops: list .5in"><FONT face="Times New Roman"><FONT size=3>1)</FONT><SPAN style="FONT: 7pt 'Times New Roman'"> </SPAN><FONT size=3>When the transmission is cold the synchros don’t synch as well – grinds easier.</FONT></FONT></P>
<P class=Msonormal style="MARGIN: 0in 0in 0pt 0.5in; TEXT-INDENT: -0.25in; mso-list: l0 level1 lfo1; tab-stops: list .5in"><FONT face="Times New Roman"><FONT size=3>2)</FONT><SPAN style="FONT: 7pt 'Times New Roman'"> </SPAN><FONT size=3>Reverse does not synch well – not even sure if it has synchros (any mechanics out there?)</FONT></FONT></P>
<P class=Msonormal style="MARGIN: 0in 0in 0pt 0.5in; TEXT-INDENT: -0.25in; mso-list: l0 level1 lfo1; tab-stops: list .5in"><FONT face="Times New Roman"><FONT size=3>3)</FONT><SPAN style="FONT: 7pt 'Times New Roman'"> </SPAN><FONT size=3>The more grinds reverse (or another gear) experiences the more it refuses to go into that gear when stopped.</FONT></FONT></P>
<P class=Msonormal style="MARGIN: 0in 0in 0pt 0.5in; TEXT-INDENT: -0.25in; mso-list: l0 level1 lfo1; tab-stops: list .5in"><FONT face="Times New Roman"><FONT size=3>4)</FONT><SPAN style="FONT: 7pt 'Times New Roman'"> </SPAN><FONT size=3>Reverse and second gear tend to be the worst grinders (second gear synchros get abused from quick shifting).</FONT></FONT></P>
<P class=Msonormal style="MARGIN: 0in 0in 0pt 0.5in; TEXT-INDENT: -0.25in; mso-list: l0 level1 lfo1; tab-stops: list .5in"><FONT face="Times New Roman"><FONT size=3>5)</FONT><SPAN style="FONT: 7pt 'Times New Roman'"> </SPAN><FONT size=3>Letting the transmission warm up helps.</FONT></FONT></P>
<P class=Msonormal style="MARGIN: 0in 0in 0pt 0.5in; TEXT-INDENT: -0.25in; mso-list: l0 level1 lfo1; tab-stops: list .5in"><FONT face="Times New Roman"><FONT size=3>6)</FONT><SPAN style="FONT: 7pt 'Times New Roman'"> </SPAN><FONT size=3>Putting it in a forward gear first, then reverse (without letting the clutch out) should avoid the reverse grind.</FONT></FONT></P>
<P class=Msonormal style="MARGIN: 0in 0in 0pt 0.5in; TEXT-INDENT: -0.25in; mso-list: l0 level1 lfo1; tab-stops: list .5in"><FONT face="Times New Roman"><FONT size=3>7)</FONT><SPAN style="FONT: 7pt 'Times New Roman'"> </SPAN><FONT size=3>If it doesn’t go into reverse, put it in forward gear and roll the car – try reverse again.</FONT></FONT></P>
<P class=Msonormal style="MARGIN: 0in 0in 0pt 0.5in; TEXT-INDENT: -0.25in; mso-list: l0 level1 lfo1; tab-stops: list .5in"><FONT face="Times New Roman"><FONT size=3>8)</FONT><SPAN style="FONT: 7pt 'Times New Roman'"> </SPAN><FONT size=3>Yes you want to be stopped when going into reverse, but if the car is ‘inching’(not quite stopped – and we’re talking really slow here) and the gears don’t line up it will pop into reverse because of that slight movement – the gears on the wheel side are rotating.</FONT></FONT></P>
<P class=Msonormal style="MARGIN: 0in 0in 0pt 0.5in; TEXT-INDENT: -0.25in; mso-list: l0 level1 lfo1; tab-stops: list .5in"><FONT face="Times New Roman"><FONT size=3>9)</FONT><SPAN style="FONT: 7pt 'Times New Roman'"> </SPAN><FONT size=3>If the gears don’t line up you can let the clutch out ever so slightly – just enough to rotate the transmission – and it will pop into the gear.<SPAN style="mso-spacerun: yes"> </SPAN>This is sensitive though - if you let the clutch out quick or too much it will grind.</FONT></FONT></P>
<P class=Msonormal style="MARGIN: 0in 0in 0pt 0.5in; TEXT-INDENT: -0.25in; mso-list: l0 level1 lfo1; tab-stops: list .5in"><FONT face="Times New Roman"><FONT size=3>10)</FONT><SPAN style="FONT: 7pt 'Times New Roman'"> </SPAN><FONT size=3>Second gear grind because of an abused/weak/cold synchro can be avoided by tapping the gas(boosting the rpm’s) up while shifting to next gear – this helps line up the gears and the synchros don’t have to work as hard.<SPAN style="mso-spacerun: yes"> </SPAN>In other words, with a normal take off you get going maybe 15mph at 4k rpm and start to shift to second.<SPAN style="mso-spacerun: yes"> </SPAN>By the time you push the shifter against the second gear synchros the rpm’s have already dropped enough(maybe to 3 or 2.5k) that the sychros have a tough time lining up the next gear.<SPAN style="mso-spacerun: yes"> </SPAN>Weak (or cold) synchros can’t handle it and you get a grind.<SPAN style="mso-spacerun: yes"> </SPAN>By tapping the gas while preparing to enter second, the rpm’s stay up and the second gear synchros have an easier time because the gears are already almost lined up by themselves.<SPAN style="mso-spacerun: yes"> </SPAN>This also makes for a really smooth clutch release into that next gear.</FONT></FONT></P>
<P class=Msonormal style="MARGIN: 0in 0in 0pt 0.5in; TEXT-INDENT: -0.25in; mso-list: l0 level1 lfo1; tab-stops: list .5in"></P>
<P class=Msonormal style="MARGIN: 0in 0in 0pt 0.5in; TEXT-INDENT: -0.25in; mso-list: l0 level1 lfo1; tab-stops: list .5in"><FONT face="Times New Roman" size=3>Ok, I know I'm a geek for actually taking the time to write this out - but what can I say - I'm ****.<IMG src=smileys/smiley14.gif border="0"></FONT></P>
