rpm shift goes crazy !!
my rpm shift point is this
shift points: 1-2 : 5900
shift points: 2-3 : 5700
shift points: 3-4 : 5700
but when im racing the shift point 2-3 goes to 6200 and somtime goes to 6500!!
what could cause this issue??
any suggestion? somthing good but wouldnt hurt the car?
please i need help this car start to make me crazy !
No, you should be shifting past 6k to take advantage of those cams. You should be fine as long as your springs are in good shape. Why did you lower the 1-2 shift to 5900?
My cams are almost identical to your VT stage 1's, and i shift around 6200-6300 on average.
Without seeing a dyno graph of your car it's hard to say, but in general i'd be looking around 6200 on average. The 1-2 shift could probably stand to be a tad higher, but again these are just estimates. You really need to have it dynoed to see where the optimum shift points should be.
Are you familar with how the 1-2 & 2-3 & 3-4 shifts happen? There is always a delay and that delay needs to be factored in when setting the shift points. Read this article and it will help you to set your shift points. http://tccoa.com/articles/tranny/tra...on/page3.shtml
here is some specific information on the delays in shifting http://tccoa.com/articles/tranny/tra...on/page6.shtml
I have my shift points set to
1-2 5,000
2-3 5,600
3-4 5,300
The actual shifts happen at about 6,000
1-2 5,000
2-3 5,600
3-4 5,300
Are you a manual or automatic transmission?
