Can i go coil over rear suspension with these LCA's?
http://www.uprproducts.com/mustang-c...e-bushing.html
These are the LCA's i was going to get, but before doing so, i want to see if lowers the car with some springs and coil over kit would make any problems. for example, you don't buy under drive pulley's if your supercharging....anything like that with this suspension. Want traction bars, as well as front and rear coil overs with eibach lowering springs. This going to work?
Those are going to be fine weather with/without CO springs/shocks. If you plan on throwin' some stickeys on your ride and lots of launches, I would recommend you go MM HD poly/sperical instead due to higher strength, IMO.
Jazzer
Jazzer
hey eric, thanks for the info, been awhile since we talked. I plan on just going on 18's 265/35's. I'll be launching maybe 50 times a year at most i'd say. after that i'll probably be getting the modular k member kit/eibach from upr, with rear coil overs with it. then bilsten/tokico shock/struts. sound like a good way to go? you said to hit you up after i made that purchase, alot longer than i anticipated, but i'm ordering those LCA's as i type. What do you suggest next.
They will be fine, but tis not how many times you launch on them, it is how much GRIP you have upon such a launch. I think they will be fine unless you go M/T's and really dig hard off the line.
Shocks/struts sound fine and would certainly go FLSFC's as the biggest single upgrade to your ride reguardless of how you drive it.
Jazzer
Jazzer
musnicki
09-23-2015 07:11 AM
09-08-2015 11:50 AM
