Do I need a fuel pump upgrade?
Old 05-21-2010, 12:27 AM
TheMustangLoveR
TheMustangLoveR's Avatar
Default Do I need a fuel pump upgrade?
Hey all, my car currently sits at about 400rwhp (full bolt-on + Vortech V2), utilizing an SVT Focus fuel pump. I just put in some blower cams and am about to schedule a re-tune but just realized that I, perhaps, might run into some fuel issues?
How much power can you make with the SVT pump? I don't want to drive halfway across the state for a tune just to be turned away because I couldn't push enough fuel.
Thoughts? If I indeed do need more pumpage, is a Boost-a-Pump an easy fix?
TheMustangLoveR is offline
Old 05-21-2010, 10:27 AM
vanquish
vanquish's Avatar
I hear that pump sometimes works for 400-450 and then I hear some people have problems with it below 400 hp so it depends.
I think a BAP would be good if you are having fuel problems. Do you know what your fuel pump duty is at now from your last tune?
vanquish is offline
Old 05-21-2010, 11:05 AM
cliffyk
TECH SAVANT
cliffyk's Avatar
The SVT Focus pump delivers 185lph at 60psi; that's about 300lb/h.
If you assume a BSFC (Brake Specific Fuel Consumption) of 0.6lb/HP; which is the general "rule-of-thumb" for f/i apps; then that's 300 / 0.6 = 505fwHP at the crank--with the pump flat out...
Figure in an 80% duty factor and a "safe" design limit is 400fwHP.
At 90psi the SVT Focus delivery drops to 143lph, 234lb/h, 390fwHP flat out...
cliffyk is offline
Old 05-21-2010, 12:33 PM
devongarver
devongarver's Avatar
I think that means get a bigger pump lol. I think a BAP would solve your issue...but I'm no pro so we'll see what others say.
devongarver is offline
10-26-2015 05:01 PM
Meystang
09-25-2015 04:05 PM
pimp2303
09-17-2015 08:45 PM
SteelerNation82
09-16-2015 07:11 AM
rksnow1
09-14-2015 08:46 PM
Quick Reply: Do I need a fuel pump upgrade?
