need help!!timing chain install - MustangForums.com
Old 05-29-2010, 11:54 PM   #1
mlez28
Default need help!!timing chain install
i just in stalled a new timing chain set with all new guides ,chains,tensioners ,got evrything together and started it and its idling at 2500 to 2000rpm and i noticed when i turned the car of i removed the oil cap and it almost blew it out of my hand, im almost positive that evrthing is lined up wright,this is my first 4.6 tear down,iv had several 5.0s...please help me
mlez28 is offline   Reply With Quote
Old 05-30-2010, 12:02 AM   #2
cliffyk
TECH SAVANT
cliffyk's Avatar
Sounds to me as though the valve timing if not correct.
Here's the procedure from the '03 shop manual...
cliffyk is offline   Reply With Quote
Old 05-30-2010, 08:36 PM   #3
EI-03-GT
hey thanks for posting that guide i am about to do a cam swap myself for the first time and i could use all the info i can get
EI-03-GT is offline   Reply With Quote
Old 05-30-2010, 11:52 PM   #4
MADMADVIC
WAS ALL UR TIMING DOTS WHERE THEY WERE SUPPOSED TO BE..11 0'CLOCK FOR PASS..1 0'CLOCK FOR DRIVER...6 0'CLOCK FOR CRANK...WITH GOLD OR COPPER LINKS ON THOSE DOTS....ALSO MAKE SURE OF NO VACUUM LEAKS..
MADMADVIC is offline   Reply With Quote
Old 05-31-2010, 07:36 PM   #5
mlez28
dude i just spent yeserday and today ripping i back apart and redid evrything and did evrything wright again start it it idles at 2000 and if i give gas to about 4500rpm it stay tha high after i take my foot off the gas and slowly dropps in rpm,im so pissed ,im pretty sure its somthing stupid ive checked evrthing dont think i have anyvacum leaks tha i know of,didnt remove any just the cranck case tube that goes from valve cover to cover
Did a few mods this summer... drfister 2005-2014 Mustangs 9 09-04-2015 08:47 AM
HP Gains Without Headers GimpyHSHS 4.6L (1996-2004 Modular) Mustang 7 08-29-2015 07:30 PM
crank no start 1st 4 eyed fox General Tech 2 08-24-2015 07:56 PM
Cam swap on 68 289 ding56 Classic Mustangs (Tech) 3 08-14-2015 03:40 AM
Need Help Diagnosing Have Codes (Confused) djbigskrilla 2005-2014 Mustangs 13 08-11-2015 01:59 PM
02, 07, 2004, 2005, 40l, 46, 46l, chain, cover, ford, gt, install, installation, modular, mustang, photos, timing
