Drag radials on New Edge
your not missing anything, the 315/35/17's looks mean from behind, I'd say too much tire for a mostly stock stang, even more so being MT's but the drag radials are not going to bite as well as the MTSS tires.
Best stick with a D/R (Drag radial)
yes sir, thats why I said it's best for track only (safety wise) they're just a nice sticky tire, more like slicks with groves.
From everyone I've talked to on the forums here and at the track, going from a 17" rim to a 15" rim makes a big difference. Yes, I did it for looks at the time I bought the wheels, but they've treated me well at the track so far. With the bigger sidewall of a 15" wheel I don't think it's necessary to go with a 315. As for a bias ply vs. a radial, I'd go with the radial if you plan on going back and forth to the track with them. Jason Lee can carry the front end 300' out on a BFG radial, I would think you'll be fine.
Are drag radials in general heavy than an average street tire for the same application or vice versa? For example- say you have a 285/35/18 NT05-aluminum 18x10 wheel setup verses a 285-ish Drag radial on a 15" prostar-would one necessarily weigh more than the other?
Sorry I'm dumb when it comes to this lol
No they are about the same weight, the size contributes to the weight and also you have to figure in how tall the tire is because this changes your gear ratio, for instance “you have a 4.10 gear but you install a tire that has a overall diameter of 30”, on a new edge mustang, the factory overall diameter of a mustang tire is 25.7 so having that tire raises your gear ratio to approximately 2.92 sitting at the line” A all stock NE stang lines up next to you will walk you because the factory gear ratio is 3.27. The Bold lettering example above is an example but there is a formula you can use to find out the true ratio with the demotions described above. Hope I explained it well enough.
yes the taller tires are for the serious hp cars that need the flex in order for suspension squat too hook, there are plenty of tires that are very close to a stock mustang tire, for example
Go here then click on the "specs" tab it will show all different sizes in the overall diam column, also in the search feature type in "drag radial" and they will show all the DR's that they sell.
