line pressure in tranny
Old 06-11-2010, 05:39 AM
fredrico
fredrico's Avatar
Default line pressure in tranny
Just installed tranny cooler and kind of concerned about maybe one of the rubber lines popping off with the pressure involved there? The hose is over the flared ends and double clamped.
fredrico is offline
Old 06-11-2010, 10:35 AM
devongarver
devongarver's Avatar
Meh, i think most line pressures are only maxxed at like 270 psi. I think you will be ok. PM WhiteFoxGT, he has an auto in his truck, and worked at a ford garage before, he may offer some good input.
devongarver is offline
Old 06-11-2010, 01:20 PM
smythge
smythge's Avatar
I would cut the line and install a compression fitting with a barbe d end on it.
smythge is offline
Old 06-11-2010, 01:56 PM
fredrico
fredrico's Avatar
thanks, didn't think of that.
fredrico is offline
Old 06-11-2010, 02:12 PM
mstngsule68
mstngsule68's Avatar
it it was me, id just run the metal lines. its not that hard to do. there's some good how to videos on youtube to show how to flare and cut metal line, as well as i bet non of us would have a problem explaining it.
mstngsule68 is offline
Old 06-11-2010, 03:13 PM
smythge
smythge's Avatar
If he is running the line through the radiator to the cooler back to the transmission without a lot of bending and various fitting he is going to be stuck running at least a couple feet of rubber line.
smythge is offline
Old 06-11-2010, 03:14 PM
smythge
smythge's Avatar
If you really want to do it right get steel braided lines with AN fitting and quick disconnects.
smythge is offline
Old 06-11-2010, 03:19 PM
mstngsule68
i thought he was talking about making the whole thing out of rubber...
Old 06-11-2010, 04:20 PM
fredrico
fredrico's Avatar
No its just an aftermarket tranny cooler. I could be wrong but they all come with rubber hoses and clamps. And yes, its true that the 4r70w trans has up to 275 psi in reverse, but there can't be that much pressure in the lines to the cooler, can there?
fredrico is offline
Old 06-14-2010, 06:29 AM
devongarver
Exactly, that is why I said you should be fine. I wouldn't imagine you seeing 100 psi even on those lines...I'll try to do some research for ya. For what its worth, I have had ****** brass fittings hold 200psi of glycol/water solution in industrial machinery, with only one stainless hose clamp...
TCStangerv6
10-11-2015 05:57 PM
88 orangepeel notch
10-05-2015 09:03 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
treesloth
09-28-2015 07:03 AM
2poor4u2
09-26-2015 11:08 AM
Quick Reply: line pressure in tranny
