Tuning Question
#21
Octane rating does not relate to the energy content of the fuel (see heating value). It is only a measure of the fuel's tendency to burn in a controlled manner, rather than exploding in an uncontrolled manner. Where octane is raised by blending in ethanol, energy content per volume is reduced.
#23
yall keep comparing fuel octanes and timing, and the energy content and price, but the truth is if you want more power use higher octane, more timing and more fuel, its true that 87 does not have the enrgy that 93 has, but the difference is so small, all you do is add a little more fuel to componsate
Simply dumping more fuel in there will throw off your air/fuel ratio. The further away you are from 14.7 the less power you're going to make. Dumping more 93 octane into the cylinder is going to make less power, not more. You'll be choking off your flame by not providing it with enough oxygen to burn and that will rob you of power. It's the same thing that happens when your engine runs super rich at WOT and falls on it's face.
Just adding more fuel to your mixture will make the problem worse, not better. Why do you think people even bother to do WOT tuning if all you had to do is dump as much fuel as you can into the cylinder?
#25
i type long messages so that makes me smartttttttttttttttttttttttttttttttttttttttttttttt tttttttttttttttttttttttttttttttttttttttttttttttttt tttttttttttttttttttttttttttttttttttttttttttttttttt tttttttttttttttttttttttttttttttttttttttttttttttttt tttttttttttttttttttttttttttttttttttttttttttttttttt tttttttttttttttttttttttttttttttttttttttttttttttttt tttttttttttttttttttttttttttttttttttttttttttttttttt tttttttttttttttttttttttttttttttttttttttttttttttttt tttttttttttttttttttttttttttttttttttttttttttttttttt tttttttttttttttttttttttttttttttttttttttttttttttttt tttttttttttttttttttttttttttttttttttttttttttttttttt tttttttttttttttttttttttttttttttttttttttttttttttttt tttttttttttttttttttttttttttttttttttttttttttttttttt tttttttttttttttttttttttttttttttttttttttttttttttttt tttttttttttttttttttttttttttttttttttttttttttttttttt tttttttttttttttttttttttttttttttttttttttttttttttttt tttttttttttttttttttttttttttttttttttttttttttttttttt tttttttttttttttttttttttttttttttttttttttttttttttt take a breath tttttttttttttttttttttttttttttttttttttttttttttttttt tttttttttttttttttttttttttttttttttttttttttttttttttt tttttttttttttttttttttttttttttttttttttttttttttttttt tttttttttttttttttttttttttttttttttttttttttttttttttt tttttttttttttttttttttttttttttttttttttttttttttttttt tttttttttttttttttttttttttttttttttttttttttttttttttt tttttttttttttttttttttttttttttttttttttttttttttttttt tttttttttttttttttttttttttttttttttttttttttttttttttt tttttttttttttttttttttttttttttttttttttttttttttttttt tttttttttttttttttttttttttttttttttttttttttttt!!!
#26
Haha thanks for the explanations guys. I honestly didn't know how the octane comparisons worked - I'll probably stay with 87 for now. I'll talk with my shop and see if they have any suggestions (they only deal with mustangs) about tuning.
Thanks again
--Mike
Thanks again
--Mike
09-08-2015 06:25 PM
09-02-2015 08:40 PM
