a/c field coil
a/c field coil
Son just purchased a 1997 gt mustang. the ac clutch bearing were worn out and needed to be replaced. bought a new coil and pully assembly. i problem is trying to remove the oild coil from the compressor housing. instructions with the new coil says to remove a clipp holding the coil on. I can not seem to find it. any help in this matter would be very much appreciated.
ac, clutch, coil, compressor, field, ford, hammer, installing, mustang, problems, rebuild, removal, replacement, ring, snap
