Driver side window wont go up!
Old 06-21-2010, 06:42 PM
Chubstang
Chubstang's Avatar
Default Driver side window wont go up!
I did indeed search, but a couple months ago my driver side window refused to go up. I came back a few hours later and it went up fine, I haven't had a problem since. Today the same thing happened, I waited a few hours and it isn't going up. I pulled the window switch panel off and tested everything. Power to and from. I also tested the relay under the dash and that is also fine. Is there anything else I can test before I have to pull the entire door panel off? I don't think it's the motor because it did the same thing before. I'm thinking it's either a bad connection at the window motor or a short somewhere because the fuel gauge randomly lit up today for a minute. The cd changer also started rotating through CD's by itself. When I press the window down button for the driver side I can hear the relay under the dash click but not when I press it for the passenger side.
Any ideas would be great. Thanks.
Chubstang is offline
Old 06-21-2010, 06:50 PM
WhiteFoxGT
Resident Ford Troll
WhiteFoxGT's Avatar
The motor has a dead spot, super common problem. True fix is to replace the motor.. want to know how I'd fix it?? Beat the bottom of the door with your hand while pressing up on the switch. It works every time. And in a couple weeks if it sticks again do the same thing.. Way cheaper then replacing the motor
WhiteFoxGT is offline
Old 06-21-2010, 08:15 PM
DreamerGT
DreamerGT's Avatar
hold the button down(with the power on of course) and slam the door shut.
DreamerGT is offline
Old 06-22-2010, 12:41 AM
Chubstang
Chubstang's Avatar
The window went up on the third door slam! Thanks
Old 06-22-2010, 12:56 AM
Fastninja
Fastninja's Avatar
I have the same problem but for both rear windows. Same fix?
Fastninja is offline
Old 06-23-2010, 06:46 PM
TRAIL BOSS
TRAIL BOSS's Avatar
Mine did the same thing yesterday.
TRAIL BOSS is offline
Old 06-24-2010, 08:05 PM
03MustangTerminator
03MustangTerminator's Avatar
Thumbs up
Newbi to this Forum. [03 Cobra Stock, 11,000 miles]
It does have dead spot in the motor. Tried beating the door with my hand gently and it worked. Now I remember closing the door and that's when it happened.
WORKED. THANKS
03MustangTerminator is offline
DreadPirateRoberts
09-26-2015 02:11 PM
2k232
09-16-2015 10:28 AM
movielover40
09-15-2015 10:37 AM
wileec
09-11-2015 10:16 AM
amandahchase
09-03-2015 10:09 AM
Quick Reply: Driver side window wont go up!
