o2 Problem!!!
o2 Problem!!!
OK so I am going on a 800 mile trip this weekend...and not to long ago i installed a o/r x pipe with mils..and my check engine light is still on..i reset the code and it come back on it says the driver rear o2 isn't working right. I think that it is messing up my gas mileage to that why i wanted to get it fixed. So i think it is either the mil or the actual sensor itself. so which one should i replace first any suggestions?
If it says the drivers rear is acting up, and you are 100% positive the code represents the drivers rear, and all you have is the Mil eliminator, I would assume the Mil is bad. Try swapping the Mil extensions right and left and clear the code to see if it comes back on the other side as a different code. What is the code you were getting BTW?
If it's worth a piece of mind type of thing, I don't think the rear O2 sensors actually control the fuel trim...I think they are nothing more than a "im happy=no CEL" or "im not happy=CEL" type of deal...
Ask CliffyK, he will know.
The rear O2 sensors serve ONLY to monitor the efficiency of the catalytic converters--ONLY. (that's a period)--they have no effect on engine operation; None, Zero, Zilch, Nada.
This is explicitly documented in the shop manuals...
OTOH, aged/sluggish/slow switching front O2 sensors can affect fuel economy--without triggering a DTC. As they get old there output drops and the PCM sees this as a lean mix, so in closed loop mode it will compensate (via the short term fuel trims) by making the mix richer = lousy fuel economy.
The O2 sensor manufacturers will tell you they need to be replaced every 50k, they are actually pretty good for 100k unless you do a lot of short trips and the engine never heats up fully--running rich causes the sensors to fail more rapidly.
If most of your driving is 10 miles or less trips, only a couple times a day, and you have 75k+ miles then replace the front sensors (yourself, not at the dealer).
The increased MPG will pay for it in short order--IF you DIY--if you have to pay someone else to do it they wait 'til you get a DTC...
Seanam
10-04-2015 10:15 AM
stangin1996gt
09-21-2015 11:01 AM
