help on block modification
How's it goin'? i'm new at the forum and i got a bored GT engine block that's already assembled, but the thing is before i go and get the heads from trickflow, i was wondering if it was possible for me to put the heads of a 01' Cobra, since i figured they were the same engine block except the 03-04 supercharged cobra. Thanks!!
u can def do that. Like above u need the front cover,intake,secodary chains,sprockets,4v chain guides,and secondary chain tensioners,and other stuff. It will end up way more expensive going 4v with that motor rather than just going with the trick flow heads! and probly will be about the same in power. plus when u go 4v aftermarket cams are gonna be around$1100!
Matt's 95 Stang
10-05-2015 07:16 AM
