Head Gasket Help and cam/crank bolt question
I'm in the market for head gaskets for my motor. My pistons are 18cc which will yield 9.5:1. I want to stay at this compression so the stock thickness. my block is a 97 GT block bored .20 over with PI heads. Do you guys all recommend Felpro? where would i order these? any help appreciated!
also, I did go with ARP for all the major components (ARP headstuds, ARP mainbolts, ARP 2000 rod bolts) but I am now at the point where I need a crank bolt and cam bolts. Do you guys think i should stick with ARP for these or would OEM bolts be fine?
Yes, stick with ARP
Head gaskets http://www.summitracing.com/parts/FEL-9790PT-2/ http://www.summitracing.com/parts/FEL-9792PT-2/
