96-98 Gauge Cluster Question
Old 07-08-2010, 05:18 AM
uberstang1
Chupacabra
uberstang1's Avatar
Default 96-98 Gauge Cluster Question
If I switch out the factory gt cluster and plug in a cobra cluster will the speedometer and tach read correctly considering the cobra cluster's MPH goes higher?
uberstang1 is offline
Old 07-09-2010, 02:12 AM
masterofthepuppets99
masterofthepuppets99's Avatar
i think you will have problems with pats if you do this
masterofthepuppets99 is offline
Old 07-09-2010, 03:52 AM
cliffyk
TECH SAVANT
cliffyk's Avatar
That should be a PATS-I vehicle in which the instrument cluster does not play a part in the PATS. PATS-II, in which the cluster and PCM are married via a shared security code, was installed in the '99-'04 Mustangs.
I have no idea as to whether the speedometer will work correctly. I believe it's a mechanical drive (could be wrong here) which would sway me toward yes, however did the GT and Cobra have he same rear-end gears in '96-'98?
cliffyk is offline
Old 07-09-2010, 08:28 AM
lizzyfan
Underboss
lizzyfan's Avatar
You'll have to swap the cluster module off the GT cluster to the Cobra cluster
lizzyfan is offline
5.0muscle
01-11-2016 01:17 PM
SteelerNation82
09-16-2015 07:11 AM
Pyrate Dave
09-10-2015 07:30 PM
96stang3.8
09-10-2015 06:42 AM
raleigh05GTO
09-04-2015 07:09 AM
Quick Reply: 96-98 Gauge Cluster Question
