1998 Mustang GT Weight?
Old 07-10-2010, 05:16 PM
ricksmastermix
ricksmastermix's Avatar
Default 1998 Mustang GT Weight?
Anyone out there know how much a stock 1998 Mustang GT weighs?
Thanks.
ricksmastermix is offline
Old 07-10-2010, 06:16 PM
SnakeConvert98
SnakeConvert98's Avatar
Thanks.
Look on the door jam drivers side , there is a sticker on there, next to the door striker, that will tell you the weight of your car!
Unless someone removed it !
SnakeConvert98 is offline
Old 07-10-2010, 06:42 PM
cliffyk
TECH SAVANT
cliffyk's Avatar
That plate lists the Gross Vehicle Weight Rating (GVWR), the maximum allowable weight loaded with all fluids, passengers and luggage, etc.--not the actual weight (often referred to as curb weight) of the car. Other numbers provided are the GAWR, the maximum weight rating for the front and rear axles, and the Maximum Load (passengers + luggage) and maximum luggage ratings.
Unfortunately no combination or calculations applied to these will get you the vehicle's weight.
The Mustang Field Guide (2005-KP Bools) lists the curb weights of '96 to '98 GT coupes as 3,227 to 3,279 lbs depending on what table you look at.
cliffyk is offline
Old 07-10-2010, 07:17 PM
SnakeConvert98
Originally Posted by cliffyk
That plate lists the Gross Vehicle Weight Rating (GVWR), the maximum allowable weight loaded with all fluids, passengers and luggage, etc.--not the actual weight (often referred to as curb weight) of the car. Other number provided are the GAWR, the maximum weight rating for the front and rear axles, and the Maximum Load (passengers + luggage) and maximum luggage ratings.
I stand corrected,,,,,,,,,,
Old 07-11-2010, 05:13 AM
trailor
trailor's Avatar
http://autos.msn.com does wonders
trailor is offline
Old 07-11-2010, 07:49 AM
jt02gt
jt02gt's Avatar
or if you want to know how much your vehicle weighs try to find a scale that your law enforcement uses for truckers pull in and ask them if they can weigh you on a non busy time and im sure they will help you out
jt02gt is offline
Old 07-13-2010, 06:31 PM
SnakeConvert98
or a farm supply store,, have one a stones throw from my house,, weighed my car - 98 cobra convertible - 3,740lbs with me in,,,, 3,490lbs me out ! Plus or minus a few lbs for accuracy !
Old 07-13-2010, 07:07 PM
945LSTANG
945LSTANG's Avatar
this
it might cost you around $10 or so IIRC.
945LSTANG is offline
NorthAmericanTuning
11-09-2016 11:45 AM
NorthAmericanTuning
03-18-2016 11:21 AM
chain
08-17-2015 08:52 AM
ccwebb
08-11-2015 06:47 PM
daytooday
08-11-2015 09:22 AM
Quick Reply: 1998 Mustang GT Weight?
