Swishing noise from motor? Thoughts??
Old 07-20-2010, 04:02 PM
Stang9946
Stang9946's Avatar
Default Swishing noise from motor? Thoughts??
http://www.youtube.com/watch?v=y3Zh7wrWOXQv Listen really carefully and you can hear it..
So there's this sound coming from under my hood. I can't pin point the location but it kinda sounds like from the front like by the alternator. It sounds like a kind of "swishing" noise. Sorta like the sound you hear if you put your ear to a screw driver and place it against your alternator. You guys know the sound I mean right? It's like that just louder.
Btw, it's not always constant. If I drive it around it does it and sitting idle, then if it sits for like 20 minutes and you start it up, it's gone but comes back about 5 minutes later.
Edit: It wouldn't be anything with the clutch would it? I just replaced all of that last summer and the new parts only have about 900 miles on them.
Stang9946 is offline
Old 07-21-2010, 10:55 PM
Repzard
Repzard's Avatar
Idle Pulley\Pulley's ?
They do sit under alternator area
Repzard is offline
Old 07-21-2010, 11:35 PM
Stang9946
Stang9946's Avatar
Yeah I think that's what it is. I should know for sure by tomorrow afternoon.
Old 07-21-2010, 11:50 PM
Repzard
Repzard's Avatar
Reason I stated that is I had to replace mine for similar noise.
Mine had two and replaced both and all noises where gone.
Simple job
BTW .. I replaced belt while I had i apart even though it wasn't worn.
Just for piece of mind.
Good Luck
repzard
Repzard is offline
Old 07-22-2010, 12:32 AM
Stang9946
Stang9946's Avatar
Simple job
Good Luck
repzard
Both of the pulleys are the exact same right? I'd need 2 Idler/Tensioner pulleys?
Old 07-28-2010, 12:35 AM
Stang9946
Stang9946's Avatar
Replaced the idler and tensioner pulley. Still makes the noise. =\
Old 07-28-2010, 09:42 PM
Repzard
Repzard's Avatar
Not sure if you solved issue yet but.
Did you replace the belt also?
Repzard is offline
Old 07-28-2010, 09:52 PM
Stang9946
Stang9946's Avatar
No, but I checked the belt for cracks and wear and it was a little glazed but fine otherwise.
Old 07-29-2010, 09:07 PM
Repzard
Repzard's Avatar
Well maybe its the water pump bearing or alt bearing?
One way you can test things is pull off the belt and spin the water pump pulley by hand and see if you hear any noise.
Also if your car has A\C could be the A\C pump .
But from your video it really sounded like a pulley or some where in that area.
My guess now would be alt bearing.
Wish I could help more.but that video its really tough to figure out.
Good Luck
Repzard is offline
Old 07-29-2010, 11:49 PM
Stang9946
Stang9946's Avatar
Good Luck
But if it were a bearing, why wouldn't it do it from start to stop and not just when warm?
Quick Reply: Swishing noise from motor? Thoughts??
