I had a question about solid motor mounts compared to the ****ty stockers. Although I have a rather mild cam the motor lopes quite a bit at idle, you can also feel it in the car when at idle, the car is rockin. I would think that having solid motor mounts would make it worse, considering there's less give to the mount to absorb the lope.
The stiffer you make the engine mounts, with solid mounts being the stiffest of course, the more engine noise and motion will be transfered to the chassis/body--it cannot be any other way...
