Stock 4.6 block HP rating
Old 08-22-2010, 03:03 PM
0949er
0949er's Avatar
My car was making 450 pulls and I was about to **** a brick when I found out. I had to buy a bigger pulley to pull those numbers down. I am still scared and I brought it down closer to 400.
What you need to take form all this is..... your car will eventually need a new motor w/ 465 rwhp. Weather its tomorrow, next month, or even next year, if you are lucky.
Are you the kind of person that like to risk it? Because at those levels it is a game.
0949er is offline
Old 08-22-2010, 08:07 PM
MU71L4710N
MU71L4710N's Avatar
Originally Posted by nickmckinney
The guys in NMRA have proved both of these wrong, Brandon Alsept spins the stock cast crank to 9500RPM and Bill Putnam ran the stock 2V PI heads to 7000RPM shifts in capturing the stock 2V longblock plus cams record of 11.98@113MPH.
As for the OP original question yes the tuner is correct, 400RWHP is 99% safe, 450RWHP is 50/50 and 500 is probably around 10% safe. Its the stock tight piston ring gap that usually fails first with a boosted motor. If the ends butt up they will break the ringland on the piston.
k well he still had cams. you will not make any power with the stock heads and cams at 7k rpm. as for the crank, he could have had it balanced or something?
MU71L4710N is offline
Old 08-22-2010, 09:34 PM
lizzyfan
Underboss
lizzyfan's Avatar
Yep, it's not "if" but "when" it blows
lizzyfan is offline
Old 08-23-2010, 04:39 AM
Soldier GT
Soldier GT's Avatar
Op you are most def playing with fire bro. Once I install my V1, 410 RWHP is as high as I will go and that's still pushing it. I would listen to these guys.... they helped me out alot with my setup. Good luck!
Soldier GT is offline
Old 08-23-2010, 03:30 PM
hellfire0990
hellfire0990's Avatar
If he put in forged pistons, the cobra crank, and forged rods, would that make 465+HP "safe"?
hellfire0990 is offline
Old 08-26-2010, 03:26 PM
TruBlu03GT
TruBlu03GT's Avatar
I def get the picture....I guess now I just have to decide on what to do. I doo like the MMR600 and the MMR900 blocks on lethalperformance. Thats probably the best way to go instead of buying forged internals for my current block. Thanks for all of your help!!!! As I read all of the comments, I could feel my butt puckering with fear. You guys are awesome!
TruBlu03GT is offline
Old 08-26-2010, 03:36 PM
lizzyfan
Underboss
lizzyfan's Avatar
Cheaper if you go directly through MMR http://www.modularmustangracing.com/
lizzyfan is offline
Old 08-26-2010, 04:09 PM
TruBlu03GT
TruBlu03GT's Avatar
Thanks! Theyre significantly cheaper! I would've gotten hosed!
Old 08-26-2010, 06:08 PM
Hangwire
Hangwire's Avatar
AMG +10000000000000000 I was hurrying to post telling him to go via MMR.
Hangwire is offline
Old 08-26-2010, 07:23 PM
Mustang_NTriangle
Mustang_NTriangle's Avatar
Originally Posted by cliffyk
Good info about the crankshafts!
Also, I agree 110%; going over 400rwHP (with 420 being the practical limit) with a stock GT bottom end is just begging for a blown engine.
yep - mine blew at 415 rwhp - you are definitely playing with fire OP.
Mustang_NTriangle is offline
Quick Reply: Stock 4.6 block HP rating
