Going to be servicing manual transmission & rear end, have some questions.
Ok, I've read in some places that the manual transmission in the New Edge Mustangs takes ATF, is this correct?
I've also seen someone just using Synchromesh and Lucas stabilizer.
Also, for the rear end what should I be filling it with? I've read that you need to add friction modifier, does Autozone carry that and if so what brand/type should I get?
Thanks.
Thanks.
I believe its 3.2qts of ATF.... I hear Mobil 1 is smooth shifting stuff.
For the rear, you'll need 3 bottles of 75-140. Depending on the brand, friction modifier may or may not be needed. I always run the motorcraft fluid with a small 4 oz bottle of their modifier.
for the tranny: (2 bottles of syncromesh) ~1/2 bottle of lucas, 1.8 bottles of syncromesh.
for the rear end:
I got all this stuff at advanced autoparts. Im sure autozone carries it too. make sure you buy a pump for the rear end, you need it and will not be able to do it without it.
for the rear end:
