Get me to 500rwhp!
Old 09-14-2010, 09:26 AM
boduke0220
boduke0220's Avatar
Originally Posted by Hangwire
Dont worry, whatever i do to my car, it will fly by yours
boduke0220 is offline
Old 09-14-2010, 09:55 AM
98redstang
98redstang's Avatar
okay guys great info thanks ill keep you posted on the progress
98redstang is offline
Old 09-14-2010, 11:58 AM
PurpleIcedGT
PurpleIcedGT's Avatar
how about a dual stage of nitrous?? Cost effective, torque out the *** and ohhhhh I dont knoww I feel like playing devils advocate today.
PurpleIcedGT is offline
Old 09-14-2010, 12:16 PM
98redstang
98redstang's Avatar
haha well i only have 8.5:1 compression so it wouldnt be as effective. Id rather put a blower on it and have the power all the time and not have to refil the bottle.
Old 09-14-2010, 12:29 PM
Hangwire
Hangwire's Avatar
Don't get too hasty sir , the 2.1L gets installed this weekend. Date with Fastlane Motorsports on Monday.
Hangwire is offline
Old 09-14-2010, 12:39 PM
0949er
0949er's Avatar
do I smell a NC 1/4 mile friendly drag event?
0949er is offline
Old 09-14-2010, 02:00 PM
boduke0220
boduke0220's Avatar
haha im just messing with ya, i let 049er take care of my light work.
Old 09-14-2010, 02:21 PM
ddmsgtr1
ddmsgtr1's Avatar
Originally Posted by oxfordgt
I would suggest a Novi 2000, procharger F1A or Vortech YSI for the blower. Sell your cams and get a good set of blower cams. Around 15lbs of boost will get you 500rwhp on that engine (if you change your cams) so use a 10% overdrive crank and a 3.1-3.2 pulley. That will get you around 15lbs on all 3 blowers and keep belt slip down. Get either the TFS intake or the eddy.
For fuel you should change out all of your lines to braided with atleast -8 feed line. Use a good external pump like an A1000 or a couple of walbros. I would use 60lbs injectors so you have breathing room. I would also suggest a meth kit.
If I go with a blower, it'll definitely be one of these three, leaning more towards and F1a or a YSI, either way with an 8 rib setup. And from everyone I've talked to about big power FI, a return style fuel system like Ox is talking about is the only way to go.
edit: Also, any one of these blowers is going to give you tons of room to go bigger.
ddmsgtr1 is offline
Old 09-14-2010, 04:34 PM
tbirdscwd
tbirdscwd's Avatar
500rwhp is attainable with pretty much any blower with the right set of cams. Seeing as how you have ported heads also, it will be even easier and require a couple less pounds of boost.
Since most people want room to grow and get bored of the power they are making, I suggest going with a bigger blower rather than going with an entry level one. A paxton novi 2000 is a badass blower and will make every ounce of power you could ask for.
edit: fuel system should be fine with a SVT Focus pump or Ford GT pump with a KB BAP running on top of it, and +55# injectors.
tbirdscwd is offline
Old 09-14-2010, 09:54 PM
Hangwire
Hangwire's Avatar
Well I have a totally stock suspension, 8 inch wide stock rims with 275 NT555S, an auto with stock torque converter, stock 3.27s and stock cams....I think that might be ugly for me haha. But we definitely need to get together I honestly really want to run your car once this is on. We should have some of the other NC guys meet up too.
You're all good dude Your car will most certainly look and sound much better than mine. And Yeah at the strip I will probably be light work for him.
Hangwire is offline
Quick Reply: Get me to 500rwhp!
