cobra caliper help
cobra caliper help
installed new 10th ann. Cobra calipers on my 03 gt. What went wrong was the damn car wont move an inch after i was done.
WHAT DID I MISS?
I have 18in wheels and i bled the brakes removed wheel chalks theres a 1/2 in gap between calipers. HELP PLS.
WHAT DID I MISS?
did you do front and rear,mess with e-brake at all,what do you mean by 1/2 inch gap,from the pads to rotors,or calipers to pads,where did you buy the brakes from,are you sure all parts were there,pads popped into the caliper,
I did the fronts only. I purchased 10 ann. Cobra calipers, they come w/ oe cobra pads and i bought cobra 13in rotors. Also i used new bango bolts if it matters. When i say clerance, i mean the gap between calipers and wheels. Thanks.
Tried the washer trick still no luck. im gonna try replacing the brake hoses with steel braided cobra ones next.
THANKS EVERYONE FOR ALL THE SUGGESTIONS.
ill update this post after i findout what went wrong.
