*** Advisory - 2000-2004 Gas Filler tube issue!
Old 09-23-2010, 09:50 PM
michiganman5
michiganman5's Avatar
Exclamation *** Advisory - 2000-2004 Gas Filler tube issue!
Hello All,
There is a MAJOR issue with the gas filler tube on all Mustangs from 2000 - 2004. The smaller tube they used on these years were coverd with a plastic sheild and two tie clips. The sheild traps dirt and moisture and causes the filler tube to RUST and eventually causes a large hole in the filler tube, which of course means lots of gas on the ground.
I did a lot of research and found a TON of people with this problem. Normally they don't know about it until they see a puddle under their car.
it's not the grommet (although that does have its' own issues).
The reason I am posting this is to save people money! Go under your car now, even when you don't have the leaking issue yet and cut the tie wraps and remove the plastic sheild. If you don't have a hole already, you may be lucky and never have one once this sheild is removed.
If you don't do this, EVENTUALLY, everyone will have to replace the filler tube which is a $120 cheapest replacement part. (found a cheap place, most are 150, or 200 at ford)
I will have posted this on the 6cyl forum as well!
hope this help save some people a little chedda!
Check out the pic (sorry for the quality)
https://mustangforums.com/forum/memb...usted-out.html
michiganman5 is offline
Old 09-23-2010, 10:20 PM
mestit3
mestit3's Avatar
very interesting... had the same problem on my gt if I filled it all the way up, went to ford and bought that little gasket/grommet deal assuming that was the problem, but it was wrecked before I ever got around to fooling with it.
mestit3 is offline
Old 09-23-2010, 10:21 PM
boduke0220
boduke0220's Avatar
not really, looked under mine today actually..its fine.
boduke0220 is offline
Old 09-23-2010, 10:58 PM
Donnie's GTS
Donnie's GTS's Avatar
glad I have a CA car.
Donnie's GTS is offline
Old 09-24-2010, 03:05 AM
cliffyk
TECH SAVANT
cliffyk's Avatar
Yeah, this is a "rust-belt", salt on the roads thing--that, and shoveling and scraping, are parts of living in New England I do not miss one bit...
cliffyk is offline
Old 09-24-2010, 06:42 AM
03BottleFedGT
03BottleFedGT's Avatar
Had to replace mine a couple months ago.
03BottleFedGT is offline
Old 09-24-2010, 07:03 AM
xterm11
xterm11's Avatar
I actually am replacing this tube tomorrow morning with one I found at a junk yard ($50 used vs $150 new). The entire section of the tube that was under the plastic shield has rotted out on mine.
Like you said the first sign of an issue I saw was a big puddle of gas under my car at the gas station.
xterm11 is offline
Old 09-24-2010, 07:16 AM
Soldier GT
Soldier GT's Avatar
thxs for the info!!
Soldier GT is offline
Old 09-24-2010, 10:25 AM
JBud02
JBud02's Avatar
I'll have to check it out on mine, thanks for the heads up.
JBud02 is offline
Old 09-24-2010, 12:25 PM
michiganman5
Even if your not leaking, it's a good idea to just remove that plastic shield. This will make sure the problem never happens! (or not as fast I suppose).
Good luck all!
Quick Reply: *** Advisory - 2000-2004 Gas Filler tube issue!
