Noise from steering wheel
Old 10-03-2010, 05:59 PM
BlackMage
BlackMage's Avatar
Default Noise from steering wheel
alright guys, When i turn my steering wheel i get a noise from the wheel that sounds like a spring, it sounds like the clock spring is rubbing on something or has broken. Im not really sure whats going on. i took a video of it so you can hear kinda what im talking about.
there is another problem that is bothering me with the steering wheel as well though. Im not sure if there are any type of bushings in the wheel where it attaches to the column, but it moves more than it should in an up and down motion, that I also show in the video im posting here, its right at the end.
If it is the clock spring, hopefully it doesnt cause the airbag to go off for no reason Thanks for the help
http://www.youtube.com/watch?v=8NF6GXjEitg
BlackMage is offline
Old 10-04-2010, 10:56 AM
BlackMage
BlackMage's Avatar
anyone got anything??
Bueller??
Bueller??
Old 10-04-2010, 11:06 AM
jwog666
jwog666's Avatar
there is for sure something wrong in the column. you should remove the wheel and inspect the clock spring, also seems that the play up and down is in the tilt mechanisim. needs to be pulled apart and inspected. good luck.
jwog666 is offline
Old 10-04-2010, 11:38 AM
BraMas
BraMas's Avatar
I'm going to say it is somewhere in your steering column that is your problem. The clock spring isn't really a spring it is more like a flat ribbon that caries the signals for the Cruise,Horn and air bag. Imagine a Recoil spring like on a lawn mower
BraMas is offline
Old 10-04-2010, 02:02 PM
cisurfer
cisurfer's Avatar
no lights on the dash? does your cruise and horn workz?
cisurfer is offline
Old 10-04-2010, 04:37 PM
BlackMage
BlackMage's Avatar
Ha lights... disconnected the bulb But i checked for the other day cuz the car was idling bad and nothing out of the ordinary other than rear O2's. And im not sure on the cruise and horn, havnt had a need to use em recently.. ill try tonight.
And back to the comment about what the clock spring is. Ive had a few apart and know what it looks like but Im just not sure what could be making the noise.
Does anyone know exactly how the combination switch works? or how it is exactly driven off the steering column for the blinkers?
Old 10-06-2010, 03:11 PM
Blacksslumina
Blacksslumina's Avatar
its a multi switch, it just basic switch, nothing special. your wheel was not put back together correctly/tightly the horn is rubbing against the head of the column. its possible that the retaining clip was not put on or came off. Take to local locksmith for a fix, mechanic my start throwing parts at it without proper diagnosis
Blacksslumina is offline
Old 10-07-2010, 08:57 PM
CobraFrenzy
CobraFrenzy's Avatar
im actually having the same problem right now, im having my buddy look at it..ill let you know what he finds out
CobraFrenzy is offline
Old 10-08-2010, 08:18 AM
BlackMage
BlackMage's Avatar
i checked the horns and cruise and everything there works. And as far as I know the steering wheel has never been taken off since ive owned it, 9 years. But if and when i do tear into it when i have time to figure it out, ill check for that loose or missing clip you're talking about.
CobraFrenzy - let me know what he finds out, its annoying when i give a ride to someone and there is a horrid creaking/rubbing noise coming from a very important part of the car haha
bjdutch2005
03-24-2017 03:38 AM
BOBCATJACK
09-14-2015 02:18 AM
robjh22
Suspension
09-08-2015 12:47 PM
09-08-2015 11:50 AM
raleigh05GTO
09-04-2015 07:09 AM
Quick Reply: Noise from steering wheel
