Car died after self car wash
1) it would literally take you sticking your air intake into a bucket of water to suck up any significant amount of water, so don't worry about that.
2) very possible you got water in your plug wells and are shorting out a cop or 2 or 3. this has happened to my car in heavy rain - rain dripped down through the holes in the hood that the hood scoop is bolted to. blow them out with compressed air like said.
3) another possibility especially if you have a CAI is you could have gotten water on the filter, and once you started the car you could have sucked some moisture onto your MAF. when this happens your maf "reads temperatures" that are WAY wrong, and your car adjusts fuel levels for something that doesnt exist. this happened to me in a bad storm one time when i drove through a deep puddle and my car wouldnt even hold idle and had almost no power. the solution for this is taking your air filter and maf off, and let them dry in the sun for a few hours.
i turned my car on 2nite when i got home from work and nothing again.
if it was the maf would it have dried more than 24 hours later even if it wasnt in the sun?
i can try your number 3 and put it out and let them dry if u think they wouldnt hav been dried already?
as for your number 2. is it possible that water shot thru the grille when i was using the high pressure water gun and shorted them that way?
so if it is indeed one of the coils thats messed up, i should check my codes and see if its throwing 1 for the specific coil thats messed up? the (P0351 to P0358). codes
i dont know if it is throwing a code after this happen bc it was already throwing a code for a stupid 02 sensor and gas cap leak
3.7L V6 S550 Tech 2015 - 2017
92
08-24-2018 01:44 AM
92 5.0stang
08-13-2015 06:46 AM
Milan Dragway
08-12-2015 03:43 PM
