throttle
throttle
ok so i went of for a drive seeing as the weather was nice and i was 2 miles from home and the gas pedal went flat. I knew as soon as it happened that my throttle cable broke. It broke right up at the throttle linkage where it attaches to a pin. Is there anyway i can fix this or do i have to buy a whole new cable?
Some of the high-end bicycle shops have assortments of replacement cable end barrel fittings, for mountain bikes, that fasten with a set screw or wedges.
I have used them on throttle and cruise control cables.
yeah i ended up getting a bike brake cable to work. I just need something good to hold it from going through the peddle connection and i'll be good. I fixed th exhaust leak and the bypass by leaking heater core. The car is almost running again. i hopefully will have some time tomorrow to finish up
JDWalton
09-24-2015 08:47 PM
