Wierd Rattle Under Car
Old 10-11-2010, 03:10 PM
Jordan's5.0
Jordan's5.0's Avatar
Default Wierd Rattle Under Car
I have discovered a rattle under my car when I stopped to get gas the car was idling for about 5 minutes then a rattle under the car started you don't hear it under the hood at all and it doesn't make any noise going down the road that I can hear once I got home I left it running but no noise and about 5 2 or 3 minutes after sitting there it started again I recently had the clutch cable dust cover off and it hasn't really been driven much since then it is really loud under the car though but you can't hear anywhere else. Any ideas on what would cause it.
Jordan's5.0 is offline
Jordan's5.0
Oh also it is a 99 GT
Old 10-11-2010, 06:24 PM
cliffyk
TECH SAVANT
cliffyk's Avatar
You left the engine running while fueling it?
cliffyk is offline
Old 10-11-2010, 06:42 PM
Jordan's5.0
No I was at the gas station putting gas in a can for the lawnmower but I have looked at it a little more and the noise only shows up when it has been in gear then you put it in Neutral is a 5-Speed throwout bearing just started chirping as well today.
Old 10-11-2010, 06:48 PM
Trip420
Trip420's Avatar
Check the heat shield on the cats.. Had the same problem here with intermittent rattling and that was the culprit!! Good luck..
Trip420 is offline
Old 10-11-2010, 07:19 PM
Jordan's5.0
no cats off road X-Pipe could it be the bearing in the input shaft doubt it would be a TOB could be possible but I've never heard a TOB make a knocking/rattle is the best way to describe it it comes out right near the front of the transmisson, shifts through all gears fine, clutch isn't slipping, nothing out of the ordinary but the noise. this is the first time the car has been driven in 2-3 weeks was today not sure what would have changed between then.
Old 10-12-2010, 02:19 PM
yamanx
yamanx's Avatar
My rattling under the car was the connector to the O2 sensor, zip tied them down and it stopped.
yamanx is offline
Old 10-12-2010, 03:54 PM
Jordan's5.0
ok I will try that before I do anything to drastic I know it will need a clutch, pp, and TOB soon anyways but I would like to fix this rattle.
Old 10-12-2010, 04:42 PM
Jordan's5.0
ok so i checked the o2's and no dice so i pulled the clutch cable dust cover and noticed the arm that comes out is scraping the cover and cutting slight grooves in it. I had the car up and cranked it and noticed the arm that holds the cable was jumping ever so slightly up and down is there any certain reason this may happen? any suggestions greatly appreciated at this point.
Old 10-13-2010, 02:54 PM
ct_white_stang
ct_white_stang's Avatar
F - Full
O - of
R - Rattles
D - Daily
I 've given up on listening for Rattles.
ct_white_stang is offline
Quick Reply: Wierd Rattle Under Car
