pros and cons of a stroker
Old 10-14-2010, 10:13 PM
EI-03-GT
EI-03-GT's Avatar
ok well whats the down side then? just the cost?
EI-03-GT is offline
Old 10-15-2010, 02:31 AM
SilvrStang
SilvrStang's Avatar
I didnt stroke my WAP block I broed it 20 over. My buddy has a 5.1 stroker in his car and loves it.
Pros: They sounds mean as hell due to the displacement over stock
Cons: Little more money for the stroker assembly
SilvrStang is offline
Old 10-15-2010, 08:26 AM
98redstang
98redstang's Avatar
yep thats about it haha
98redstang is offline
Old 10-15-2010, 09:18 AM
WannaBeGearHead
Go Texas!!!
WannaBeGearHead's Avatar
Man up and do a stroker big bore...you won't though.
WannaBeGearHead is offline
Old 10-16-2010, 07:39 AM
Chris98Gt
Chris98Gt's Avatar
To be honest, I had big plans of doin a big bore stroker setup. Then I started looking at the power people were getting out of forged stock bore/stroke 4.6's and decided for my goals I didn't need to spend the extra money just for the cool factor. For an N/A or nitrous motor It might be worth it, but for a boosted motor I don't think it is.
Chris98Gt is offline
Old 10-16-2010, 10:15 AM
zero2005
zero2005's Avatar
what i heard for turbo's is that the stroker will help the spool time. not that its a huge deal, since a properly sized turbo will spool fine with a 4.6 anyways and theres a bunch of other factors there too.
btw, anyone know if its worth it to buy an MMR block? i guess its really dependant on persons opinion, but i'd really like to learn to build my own motor. would it be cheaper to build it myself?
zero2005 is offline
Old 10-16-2010, 10:39 AM
grogan
grogan's Avatar
im going with an rgr built 4.6 stroker to a 5.0
pros for me, lighter wieght (aluminum block, gonna be able to pound out 22 pounds of boost, gonna make 800+ hp)
cons: costing me 4800 for the block and internals, 2000 for the trick flow heads, and 700 for the comp cams stage 4 specs. gotta get a new flywheel and flexplate being the crank is an 8 bolt. etc.etc.etc.
grogan is offline
Old 10-16-2010, 11:14 AM
ctgreddy
ctgreddy's Avatar
i believe with strokers the big thing you get is a torque increase. which obviously helps low end. atleast that was the big increase on my 347. but i believe if you're boosted just save the money you'd spend on stroking it and just get some blower cams.
ctgreddy is offline
mapitts
05-11-2016 10:14 AM
jerrytubes
10-23-2015 12:11 PM
Brett Ludlow
09-23-2015 06:59 AM
EASTIDEE123
09-14-2015 03:52 PM
Doogie65
09-06-2015 02:55 PM
Quick Reply: pros and cons of a stroker
